First lathe, questions about old Goodell Pratt #125
Results 1 to 3 of 3
Thread: First lathe, questions about old Goodell Pratt #125
    Oct 2012
    Default First lathe, questions about old Goodell Pratt #125
    Hello all,
    Well, my Dad finally handed down his old lathe, a Goodell-Pratt #125, and I've been having some fun ( and success! ) turning on it, but I have a few questions that I hope can get answered. Please forgive my 'novice' terminology.
    First, the headstock chuck comes with 2 sets of 'teeth', one that steps towards the outer edge, one that steps towards the center. The outer step set is complete (it was on the lathe), but unfortunately I only have 1 of the 3 inner step teeth. I assume both types are needed to hold various types/sizes of materials. Does anyone know where I could find those teeth for such an old machine?
    My second question is about drilling a hole exactly down the center of a dowel. I have a drill press, but that would require the dowel to be perfectly parallel to the bit and placed exactly on center, which, something tells me, wont be easy. Is this easier to do on the lathe since the dowel is spinning instead of the drill bit? If so... is the tapered 'bit' (Morse taper?) on this tailstock a common size? I see a #1 and #2 here :
    Lathe Chuck and Tapers | Rockler Woodworking Tools
    I have an old drill chuck I could use, so can I buy just a 'taper' that has threads to screw the chuck on?
    And last is it worth getting a live center instead of just the point?
    4 Pc Drive Center Set for #2MT Lathes at Penn State Industries
    Thanks for any advice and I can post pics of anything if it helps.
    CNR
    Jun 2008
    canada
    This is a wood lathe? If so I suggest re-posting your questions in the Woodworking Machines -- Wood Lathes/Mills forum. All the best with the lathe, hope you have fun.
    Aug 2015
    Default Re: First lathe, questions about old Goodell Pratt #125
    This is a Decent little lathe that can be used for Metal or Wood. I use it for Clock Repair.
    The Headstock will be a Morse Taper 1 (MT1) and the Tailstock will be a MT0.
    If you have a Slide Rest, the feed screw threads are exposed and wear bad. Problem is, It's a 3/8"-20 Left Handed Thread using , as far as I can tell, a British ( BSF) thread pitch. so order the Die from Britain ( $40 with shipping today). I hope the block in the rest will work with a new screw - but a 5-1/2" long screw isnt available - hence the Die to cut My own.
    Eric
