Really cool, I'll have to do that on my G0602 sometime.
I've used a similar clamping bracket on the tailstock shaft and a dial indicator on a mightymag,
that only got me 2 inches though.
Gotta try this, thanks for sharing.
Hoss
Here is something that I have not seen before. Wanting to know exactly how far I was drilling into material being turned in the lathe, I came up with an interesting Tail-stock DRO.
I started with a 4 inch linear DRO, drew and CNC cut a mounting bracket for the tail-stock shaft out of .125 aluminum, and then bent up a piece of .032 aluminum to hold the DRO indicator to the tail-stock.
Drilled and tapped three holes in the bracket, drilled and tapped a couple of mounting holes in the tail-stock for the bracket, assembled it on the tail-stock and away we go.
See pictures below for the details. By the way, if you want the CamBam file or G-Code for the shaft mounting bracket, let me know and I will send it to you.
My next project will be to fit a 6 inch DRO to the bed so I can see exactly where I am cutting. Will post pictures when that is up and working as well.
Click on the pictures below to make them full size.
George
Hoss
[URL]http://www.hossmachine.info[/URL] - Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL] - [url]http://www.bf20.com[/url] - [URL]http://www.g0602.com[/URL]
Not nearly as pretty as yours but I did this a few years ago on my 9" South Bend.
Dave
Dave->..
Hi there Hoss and Dave:
Hoss, glad you like the idea, it rally seems to work very well.
Dave, I can no longer say I have not seen this done before. You really made a very solid looking install. I also noted the plastic covers over the face of the DRO's. If I start getting stuff on mine I will probably do something similar.
George
I like it George!
<a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
<a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
<a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
