Circle milling
Results 1 to 3 of 3
Thread: Circle milling
    bq911's Avatar
    Oct 2023
    Default Circle milling
    Hello all,
    I have a question about locational accuracy of a circle milled boss. We have an older Bridgeport Mill Slide with a Centurian 6 control. We clock in a piece of round stock, circle mill a diameter at the desired location. We then clock the machined diameter and the location is between .0035 to .004 off center. Any thoughts?
    Thanks,
    Bill q
    bq911's Avatar
    Oct 2023
    Default Re: Circle milling
    P.S.
    The machined boss is round within less than .0005.
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    The head is not perpendicular to the table ?
    Try having the indicator set to about the same distace out as the cutter, or tramm head to be perpendicular.
    Backlash in table leadscrews ?
    Indicate an edge winding in one direction to clock zero, observe readout value. Go past, and wind back to clock zero.... you should have same readout value.
Circle milling
Circle milling
