What type/make of motor is it?
What are the part numbers of the drives, I have used Glentek in the past.
Thinking about putting a 4th axis on my machine and it is pre wired and uses Glentek drives, I have a spare Servo Dynamics card and it looks just like the glentek, would i be able to use it, did glentek become servo dynamics or the other way around.
Now I looked in the manual and it says I have servo dynamic drives and the model as the two spare drives that i have sdfpo1525-17-405 except my machine has glentek ga370-3, i have the SEM for the servo dynamic drives so i think It will work, plug connectors might be a bit off but i did save the cables when i scrapped a machine. i don't really need a 4th axis but i've got the bits and it's winter here if you know what i mean.
thanks for getting to me.
ray.
Glentek is/were nice drives, I assume you are using it in the current mode, not voltage mode with tach?
I don't know how it is set up with milltronics.
