Originally Posted by
cbChris
I've been using a "stock" one from a few years ago. I haven't tried the latest one because I have modified the stock one to suit a few preferences of mine. I have a partner 1 and the stock one turns the coolant on at tool change height which can make quite a mess when running a larger facemill. I have it to where the coolant comes on at the clearance plane. There's a few other tweaks I have done also. The stock one should get you going though. There is a manual out there on the web from autodesk that tells how to do post modifications also.
Sent from my SM-N960U using Tapatalk
