- Need Help!- Milltronics ML-15 Spindle Encoder
I need to replace the spindle encoder on my Milltronics ML-15 cnc lathe.
Milltronics quoted me $950 this is my garage lathe and don't want to spend that much, can anyone help me out with a replacement.
This is the information on the encoder.
Dynamics Research Corp.
152-121-1000-18WAS
SERIAL NO. 5692443
Channel A+
Channel A-
Channel B+
Channel B-
ZR+
ZR-
Ground
+5VDC
Any help would be greatly appreciated.
Thanks Mike
Re: Milltronics ML-15 Spindle Encoder
I had checked for replacements on my mill back in 2013, below is the info I got from MicroE Systems. My parts number was different, so you probably need a slightly different model, but this should give you somewhere to look.
Hello Brian,
Thank you for your inquiry. The "direct" replacement for your old 152 encoder is the S154 - 4E18 - 47500.
The only difference between it and your encoder is that it will have an 18" shielded cable rather than loose wires.
This encoder lists for $310 each for quantity 1-9 pieces and carries an 8-12 week lead time.
To place an order, please contact Lisa Braga in customer service at lbraga@gsig.com or 781-266-5644.
Regards,
Dave Smith
Sr. Applications Engineer
MicroE Systems
A: 125 Middlesex Turnpike
Bedford, MA 01730 USA
T: 781-266-5894
F: 781-266-5112
E: dsmith@gsig.com
W: Please Wait... | Cloudflare
Hi Catch22, I have replacement encoders for thee Milltronics. $285.00
give me a call
Sportybob
952-288-6340
- You may not post replies
- You may not edit your posts
Forum Rules
