DNC problem with milltronics centurion 6
Results 1 to 2 of 2
Thread: DNC problem with milltronics centurion 6
    Default DNC problem with milltronics centurion 6
    Hello
    we can RS232 load programs through cimco into memory no problem.
    when we try to dnc larger programs. the mill will run for a while , then watching the verify the tool path will go past what appears to be the buffer.
    Its almost as the control cannot take more information and the program errors out.
    looking at the screen error 501 illegal address. the block only has a few numbers, it has the y value but x is missing
    is this a control problem or a cable problem
    any help will be greatly appreciated
    Gord
    Member machinehop5's Avatar
    Aug 2009
    Default Re: DNC problem with milltronics centurion 6
    ...most likely the cable if, randomly crashes in DNC.
    #1 causes are USB to Serial converters and/or unshielded RS232 cables.
