- Setup Centurion 7 controller as offline trainer/simulator?
Long story short, I have access to a Cent7 control panel that was taken off of a VM15-30. I was wondering if it would be possible to use it as an offline trainer/simulator.
Currently I’m able to boot up and start to load the CNC 7.7382 program, but of course it errors out with “interface not detected” since the fiber optic cable from the NCB board doesn’t go anywhere.
Is there any type of jumper configuration on the NCB board that would allow the control to fully boot? Or does anyone have any documentation pertaining to the PC-NCB-03 board?
Re: Setup Centurion 7 controller as offline trainer/simulator?
Well I managed to find one jumper position that allows the control to initialize and load the CNC program.
However, I am unable to make/edit or load any new programs (buttons greyed out) and I cant get into F1 Setup (also greyed out) either.
Is this due to the 449 drive fault error?
...build a very small traveling salesman kit...with all the motors, bells and whistles. Great Idea
If you use Fs can you plug in a keyboard then?
- You may not post replies
- You may not edit your posts
Forum Rules
