need help: EOF RS232 serial upload. not seeing end of file.
Results 1 to 8 of 8
Thread: need help: EOF RS232 serial upload. not seeing end of file.
    Dec 2011
    Ireland
    Default need help: EOF RS232 serial upload. not seeing end of file.
    Hi I've spent two trying to send a text file to my centurion 6 via RS232 serial port from linux. I have gotten the centurion to receive all of the text but it doesn't recognise the end of the file. It keeps waiting for more with the only option to abort. The linux machine is happy. It believes the full file was sent. Is there a handshake or some other setting for EOF? I tried changing the params eof from 000 to 037 but it didn't help. The file starts and ends with % and all of the file's content is displayed on the centurion screen correctly.
    Thanks !
    Member machinehop5's Avatar
    Aug 2009
    Default Re: need help: EOF RS232 serial upload. not seeing end of file.
    ...try ending with ASCII Code "CONTROL+S" which is named Device Control 3
    https://www.google.com/search?client...code+control+S
    or might be a CONTROL+D for EOT
    https://en.wikipedia.org/wiki/End-of...sion_character
    Dec 2011
    Ireland
    Thanks for the help. Is this normally required? I have not seen this in any of the documents. I will give it a go today.
    Dec 2011
    Ireland
    Hi machineshop5,
    I tried sending the control codes you suggested plus a few others but no dice. All of the text file is still received but the centurion still sits there waiting for more.
    My settings are :
    baud 19200
    7E2
    XONXOFF
    No other settings are set.
    Am I missing something?
    Aug 2009
    ...not sure why its not finishing transfer because I am not a Milltronics type guy...I'm just guessing what your problem is and you said you tried using the "%" already right? Could try "Hardware Handshake" instead of XONXOFF if, your RS232 Cable is wired correctly.
    Hopefully a cnczoner will chime in sooner or later to help.
    DJ
    Dec 2011
    Ireland
    Thanks again. Turns out there's nothing wrong with it. That seems to be how it works. I just watched this video and it ends the same as mine. The cnc just waits for you to press the abort button. The code is actually loaded into the machine and can run. I thought aborting it didn't save the file.
    Solved now. Thanks!
  7. #7
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    Congratulations. Quite strange when you need to abort communication in order to complete the serial transfer.
    Did you try just long block of 00000 at the end? It's also possible that cut of connections wold be recognized as the end of the transfer. Means - try to disconnec the cable.
    Just for curiosity.
  8. #8
    Dec 2003
    I agree it is strange, traditionally the % mark has been used for start/stop transmit/receive?
