milltronics centurion 7 - Startup error 188
Results 1 to 2 of 2
Thread: milltronics centurion 7 - Startup error 188
    Member 2016509's Avatar
    Apr 2021
    Default milltronics centurion 7 - Startup error 188
    Hello
    milltronic centurion 7
    "runtime error 188 at 0010: 00e3"
    picture attached
    the car stops at any moment and I see this screen.
    restart helps, but after a while it repeats.
    Does anyone know this error?
    Attached Thumbnails Attached Thumbnails milltronics centurion 7 - Startup error 188-169597950_149937253719775_861273628529274165_n-jpg
    Oct 2017
    Default Re: milltronics centurion 7 - Startup error 188
    You want that topmost error code, error 956.
    In the Cent7 manual:
    188 Also appears as error 956.
    Interface card communication failure
    Centurion 7 and 7000 Series only
    CNC Version 238 and newer
    NCB Firmware 3.19 and newer
    No information was received from the interface card for 10 heartbeats
    of the control, about .01 seconds.
    CAUSES:
    1. Fiber-optic cable loose.
    2. Bad interface card.
    3. Bad NCB card, since it must receive the information from the interface card.
    4. Bad fiber-optic cable.
