- Milltronics VM25 C7 2003
Hello
I have Milltronics VM25 C7 2003 , recently having issue with M19 spindle orientation . I have been told by Milltronic Service , it seems Spindle Motor is failing and need to be replaced. looking for feed back and suggestions?
thanks in advance
Re: Milltronics VM25 C7 2003
Hi Mill, you most likely have a Yaskawa spindle motor / drives/ the motor has an encoder that is used for spindle speed and the orient position. the orient position s send to the spindle drive " orient board" then is translated to stop at the programmed orient position. It might be an encoder, or orient board or a spindle drive problem.
You will need a meter to run some checks.
Give me a call so we can run some checks.
Sportybob
952-288-6340
Hi Bob
the problem is there when the motor is cold , as the motor warm up and running , it get better . so on that base i was told the motor is failing .
- You may not post replies
- You may not edit your posts
Forum Rules
