- Need Help!- Milltronics Partner 1 VM24
We have a Partner 1 which had some hard drive problems and was reset but it seems to have reset the parameters file back to default does anybody have the correct parameters for this machine? It is a VM24 Partner 1 Centurion Controls V5 with a 20 tool changer.
We have managed to get some things to work but need the full settings.
If anyone could wither send a pfile.dat of a working machine or screen shot their settings that would be great as machine is out of action atm.
Re: Milltronics Partner 1 VM24
Hi APJB I would need to know the machine serial #.
Give me a call.
952-288-6340
Sportybob
Hi ApJB75, With the machine serial # I can pull up the factory parameters for that machine. Generic parameters might get it to boot up, but depending on what spindle drive, and or other options, you need the correct NCB or Acro files for the machine / control / options.
Give me a call
Sportybob
952-288-6340
- You may not post replies
- You may not edit your posts
Forum Rules
