Dorian Smart Dex jamming
Results 1 to 1 of 1
Thread: Dorian Smart Dex jamming
    Jun 2007
    Default Dorian Smart Dex jamming
    After a long and frustrating journey , I have finally solved my problem with the turret indexing , or jamming when it gets an M6 command .
    Several years ago I had a situation where the turret would not lock .
    Then I had a problem where the turret would not unlock , and just hum and go into a fault .
    In both cases , it turned out to be the MAC air control valve on the back of the Dorian control box .
    Now wanting to get into too much detail here , but if your MAC valve is hissing when the turret is " at rest " then it is out of adjustment ,
    and will cause all sorts of problems . ( like diverting air to both sides of the locking cylinder ) .
    I will post my maintenence report if anyone is having a similar problem .
    Considering that the MAC valve assembly is pretty cheap , it is worth a try to replace it .
    Sleve_Hope's Avatar
    Apr 2020
    Default Re: Dorian Smart Dex jamming
    That's good to know, that you are willing to help..!
