- Thread milling a bolt pattern 9000 control
Have a VM4222IL and making a part with
6 bolt hole 3/8-16 at a 7.5" diameter
There is a bolt hole program in conversational, it can tap also. Wanted to thread mill this part.
There is a thread mill program for a single hole. But can't find one that does the bolt pattern to save time in programming.
Any ideas?
Re: Thread milling a bolt pattern 9000 control
I would create the thread mill code as a subroutine and the use positioning to the center of each hole to be machined
The bolt hole cycle is probably only allowing you to use G81-G85 ---drilling thru boring cycles
i am not familiar with your control as to how you will do subs but this is what i do for a haas control
G0X7.5Y0.
M97P1000
G0X0.Y7.5
M97P1000
M30
N1000(THREAD MILL)
G0Z.100
G1Z-.500F50.
G1G91G41X.1875F10.0(INCREMENTAL MOVES)
G3X-.375Y0.Z.0312I-.1875J0
G3X.375Y0.Z.0312I.1875J0.
G3X-.1875Y.1875Z.0156I-.1875J0.
G1G40Y-.1875
G0G90Z.100(GO BACK TO ABSOLUTE HERE AND RETRACT FROM THE HOLE)
M99
- You may not post replies
- You may not edit your posts
Forum Rules
