- Need Help!- Monitor has problems on start up
Re: Monitor has problems on start up
I was able to get the monitor to start correctly, ran all after noon no problem. Restarted this morning, same problem. Had to restart 5+ times to get the monitor to start correctly.Will call Milltronics on Tuesday
Your CMOS battery on the mother board is about to die.
Give me a call
952-288-6340
sportybob
Thanks Bob, thru trial and error I figured it out.
The monitor would start correctly on the 7th time the machine was started, each time the pattern on the monitor was different always starting on the 7th try. I assume it was going thru the all the different monitor profiles since the cmos batt was dead, with the 7th one being correct for my monitor . New 2032 on the mother board solved my problem.
I did a screen shot on every page in Bios before batt swap, pretty straight forward after that
- You may not post replies
- You may not edit your posts
Forum Rules
