- RW15 - Did i erased parameters?
Activation process
Good day, i erased almost all nc files in c/parts, but now i cant do a tool change nor a peck drill, it gives a 502:undefined canned cycle, i just want to know if i deleted the macros(?) Or something important, the machine is missing the recovery file and i talked with milltronics and the say it costs $100 so i want to be sure before i buy it. Thanks
Re: RW15 - Did i erased parameters?
unless someone made a "special" M or G code file to run, the peck id built into the software. the tool change macro should be located in the "TC" folder.
call me 952-288-6340
sportybob
- You may not post replies
- You may not edit your posts
Forum Rules
