2003 vm25 7 control
Results 1 to 4 of 4
Thread: 2003 vm25 7 control
    Member positiverake's Avatar
    Sep 2005
    Default 2003 vm25 7 control
    How come when I use cutter comp this machine comes in at a angle even when I program it to come in 90 deg (perp) ? parameter? Thanks
    Mar 2017
    Default Re: 2003 vm25 7 control
    You have to program a lead in. Perpendicular or at an angle or maybe even arc. You cant come in straight. It compensates in the first move.
    Sent from my SM-N960U using Tapatalk
    Sep 2005
    Thanks for the reply, yes I do have a lead in, I program it to come in at a perpendicular line to pick up the comp and the control moves in X and Y
    I did see a parameter in my fast cam2 that might fix this, I also seen some other posts asking the same thing, I will see if the parameter is the same in the machine, I did not see it in the programming manual.
    Sep 2005
    Yes the parameter 90 degree cutter comp works
2003 vm25 7 control
2003 vm25 7 control
