Why do you even need the p program? Where are you transferring from?
Sent from my SM-N960U using Tapatalk
I am trying to move programs to a milltronics machine. The only way I have to do this is with a floppy so I am limited on size. My question is, does the O program and the P program have to be the same? That is what I have been told but to me it seems like such a waist of space. So right now I am limited since every program I move is actually double its original size.
- Problem- program of tab program in mori sv 400 and program tool chance
- Program recomendations for fanuc drip feed/program input/output
- Need Help!- Troubel looping a program in a 5 axis lathe program (sub spindle won't line up)
- Need Help!- Milltronics centurion V program?
- Problem- milltronics erroe 02 when trying to run program
Are you using fastcam or cadcam?
Go into parameters enter the password, I think it is under control make sure "use full dos names" is set to yes. No dnc necessary.
Hi Russell, There are several ways to load programs. how you load and run it will depend on the available memory (Parts storage) RAM, . If the control has been updated to a Single Board Computer ( SBC) etc,
If it is a SBC I have a program I wrote to zip up about a 4.5MB CadCam file Zip it up and be able to UNZIP directly into the control thru the floppy drive or one of my USB floppy emulator drives This works on SBC and controls that are booting from a hard drive.
From there, a couple of other option become available,
I can even update your control to use a thumb drive, This is a full 2GB "hot swappable" thumb drive system that works in DOS. I call it my Super SBC control update.
Give me a call
sportybob
952-288-6340
