Replacing X Cable Questions
Results 1 to 12 of 12
Thread: Replacing X Cable Questions
    Member sen2two's Avatar
    Jan 2010
    Default Replacing X Cable Questions
    Not sure which color wire goes into which pin location at the x axis cable. The connector has only red and black wires. And they are only numbered one through four. Whereas the DC Servo motor is colored, and also numbered. Similar to the new cable, but not axactly the saem colors for all 8 wires. I'm hoping the numbers are identical and I will match them that way.
    Attached Thumbnails Attached Thumbnails Replacing X Cable Questions-20190118_222129-jpg   Replacing X Cable Questions-20190118_214348-jpg
    Jan 2010
    Default Re: Replacing X Cable Questions
    Not sure why they came in sideways. I loaded them to IMGUR to correct this
    Mar 2017
    Does this help?
    Sent from my SM-N960U using Tapatalk
    Jan 2010
    No, but thank you for those. However I do have them already. Unfortunetly they do not tell me where the pin wires go into the connecter.
    Mar 2017
    The first pic shows the pin numbers for the encoder wires, 1-12. The other 4 wires go to the servo drive
    Jan 2010
    Ah ha! I did not see last night that the cable connector had the numbers on them. Now that i have more light this morning, I can see them.
    Stay tuned.... I am sure I will have more questions.
  7. #7
    Jan 2010
    ok, so I now have the 8 encoder wires pinned into the connector.
    From the original cable, there was this attached to the cable.
    on the bundle of 8 wires there is this green wire that is coming out. It makes sense to me this will go to the green wire removed from the other. But I want to be sure.
  8. #8
    Jan 2010
    Also, these 3 wires. Red, Black, Green are for the Armature Cable according to the diagram provided. I am unsure where these go?
  9. #9
    Mar 2017
    On my knee mill they go into the round connector then to the contractor, then to the servo drive.
  10. #10
    Jan 2010
    after looking at the schematics. I got it all together. i just get very paranoid when it comes to wiring things. It's not really in my wheelhouse.
    All wires are connected and cable is installed! Just have to put a few things back together and see if this solved my issue!
  11. #11
    Jul 2010
    Hi Sen2, You should have called me. ( you still can ;-)) I offer a better cable that I designed and speced out., shielded braid on tach, encoder and an overall shield. comes with instructions and tech support for about $200 less then Milltro. look at the motor end of the cable, see that black heat shrink, that will open up and allow coolant to work thru. My cable I use double wall adhesive lined marine heat shrink. see how stiff your old cable is. My cable will not ever do that.
    have encoder kits as well.
    sportybob
  12. #12
    Jan 2010
    Hey Bob. I do have your cable and it is now fully installed. The instructions were very clear once I took a good look. More or less, 8 was just nervous about the removal and install of the cable. Which led my to space out a little when looking at the provided schematics.
