- Machine decided to home x in the opposite direction
Left the machine not estopped overnight, not my normal practice. But I warmed it up in the morning and everythings been going well.
Experimented with G88 and the machine hung above the part cycling but nothing going on besides that. Halting the program and restarting, trying to run a different one, etc. Nothing worked. The tool changer wouldn't sync up so I couldn't change tools verify tools etc.
Hit estop to shut down and the entire machine went dark. Giving it a few minutes it booted back up but when I homed it started going in the wrong direction on X. Aborted that, its now powered down. Giving it a breather now while I post this. Opened the back door in case it was a heat issue but I don't feel anything abnormally hot.
Think I got it all sorted
Re: Machine decided to home x in the opposite direction
Maybe not all sorted, but its homing correctly again.
Doing any sort of tap op royally screws the machine up though. G84 or G88 and the machine sticks at that line. Estop or halt and tool changing stops working (it will orient but not register it did that and get stuck) Reboot sorts it out.
I'll post a thread with a good title for this issue.
DOyou think the post you provided isnt good? I was going to give it atry tomorrow and see if rigid tapping works.
- You may not post replies
- You may not edit your posts
Forum Rules
