- Error Message on startup
Re: Error Message on startup
Hi gunmaker, Error 187 is saying that the NCB board and the interface panel has lost communication.
1st thing to check is the 5VDC power supply and check / set to 5.2VDC. if the 5V falls to 4.999999999V it will drop the communications. that is why it should be set to 5.2V.
There are other possible problems, bad NCB board, interface problem. but lets check the easy stuff 1st.
Give me a call 952-288-6340
sportybob
Thanks Bob. I'll get back to you after this weekend. Gotta maintain my kids car to get him back to college.
James
- You may not post replies
- You may not edit your posts
Forum Rules
