Originally Posted by
sportybob
Hi Yugami, A couple things to check., 1. the tool push out. measure between the spindle nose and the top of the tool flange. when push out is pressed. You should get about .100" adjust the knob on top of the drawbar cylinder.
2. check the tools and spindle taper for cleanliness. WD-40 real fine scotch bright is good for cleaning tools and tapers.
3. check the air pressure to the drawbar cylinder. use a separate gage with a Tee fitting going into the cylinder. Just because the input pressure is 100psi does not mean that all points in the system has 100psi.
4. set the power parameter " drawbar delay" to about 1 sec.. remember to cycle the power after the Powere pram change.
sportybob
