- Replaced the Z bearings - YAY - now onto excess error
Tests over the weekend were satisfactory now I just need to relevel the machine and the Z is within my tolerance needs. Lucked out and found an exact match on Ebay - BIN and haggled with the seller who then shipped them very quickly.
Now, I had left off my restore with some odd readings in the Axis Card gain setting verification (Between the transit problems with some stuff shaking loose and some weird fixes I'd ran into I was wondering if this was tweaked). I had to fix one of the Balance Pots but when I did the Pin 11 and 12 verifciation I'm seeing around 12V not 6. Did this change at some point with upgrades? My machine was upgraded at some point
I'm using the guaidance from my setup manual (Centurion V Start-up Manual November 1, 1990) Page 12
Re: Replaced the Z bearings - YAY - now onto excess error
Did you change the rails and the blocks or just the blocks?
ron
Rails and blocks full matched set. Mine where complete garbage
Hi Yugami, I assume you are trying to set the gain and balance on the ACRO cards.
Give me a call I will get you the info.
sportybob
- You may not post replies
- You may not edit your posts
Forum Rules
