Replacing Partner 1 Brushless Servo Amps - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Replacing Partner 1 Brushless Servo Amps
  1. #13
    Feb 2018
    Default Re: Replacing Partner 1 Brushless Servo Amps
    I finally got the override to load and used it to check the Y axis - motor spun but errored or with excess following error instantly - thinking that may be telling me its turning the wrong way so I have swapped the polarity of the input to the amp. Was not able to get the override to load again. Acts like my Cycle Start switch is not working. I have a spare switch so I will swap it out and try again. Need to look up the post from Sportybob that tells me how to look at the inputs and outputs to the controller to see if it is one I can see change in the screen.
  2. #14
    Feb 2018
    Tore into the control panel and found 4 switches that were not making contact every time they were pressed. Has some used switches so I replaced those and things work a lot better now. Have the x axis jogging. Guess I'll move on to the y next.
  3. #15
    Feb 2018
    Been away from this project for quite some time but finally worked on it Saturday. I was able to get the Y axis servo up and running. Had to swap the phasing of the Hall sensor wires to get the motor running smoothly in both directions. Still having issues with the Z axis. That servo motor was rebuilt and has a different encoder than the Y motor, so unfortunately, I can't just copy what worked on the Y axis. Also getting some run time errors now - those concern me. Error 192 Run Time Error, History line Main, /error Address 0008:0109.
