- Partner 1F move pictures
Re: Partner 1F move pictures
All in all A nice job. one thing worth mentioning, Once again I see the Z axis held up by putting the block under the nose of the spindle. That does not help the spindle bearings at all. That's $2K of bearings in that spindle.
place the block behind the spindle nose !!!
sportybob
Thought I did enough research before the move, but apparently I missed that little gem. Hopefully all is well. Slowly working through getting everything setup. Had a few things vibrate loose inside the electronics enclosure but nothing damaged and everything is working again.
One of the Stops might be slightly out of place. Jogging the X I went too far and had the machine fault out. Had to power down and turn it by hand just a tiny bit and then when powered back up everything was fine again.
Hi Yugami, To jog off the limit switch, coming out of an estop error 450, press and continue to hold in the reset button, go to F2 jog and jog away.
sportybob
- You may not post replies
- You may not edit your posts
Forum Rules
