- Powering up the machine
Re: Powering up the machine
Per your pic, the machine is not connected properly. The black wire to L1, the white wire to L3, the green wire to the right corner 5/8 nut the red jumper L1 to L2.
what is the white wire going to the 5/8 nut going to?
sportybob
The white wire was capped off in that picture. I removed it and ran the green wire to the stud. This was the before picture. I should have made that clear.
Now that I have everything I need to plug the machine in. I wanted to make sure I understand how to place the wires from the power cord to the receptacle.
Here's a picture of the outlet receptacle I am using and the wires from the power cord. Obviously the black is the ground (u-shaped).
But I am unsure on which goes to the larger flat prong and the smaller flat prong with the white and green wires.
- You may not post replies
- You may not edit your posts
Forum Rules
