- Need Help!- rotary phaze converter
I have a 20 hp. Des-co rotary/static converter, there is an on delay switch in converter box. I could really use the wiring diagram. I need to know where the input wire should be connected on a Dayton on- delay 1amp. To one of the 120 volt input? Wiring phase converter to Willis 1050 microcut Anyone have a schematic for this?
- You may not post replies
- You may not edit your posts
Forum Rules
