That is probably the number two machine I would pick for a garage period. Yes it will run on single phase. There are so many features that make it ideal for a garage. The coolant tank is only about 12 gallons, which means you don't have 80 gallons to deal with if it should go bad. It's short enough to fit under an 8' ceiling and go in a 7' wide door. Light enough to move with a heavy pallet jack. The fiberglass enclose tends to have it's drips, but never rusts. No auger means the chips can sit and drain, conserving coolant. Most were Grease lubricated, which means no tramp oil. Parts are relatively cheap and most are easy to get at. It has a granite composite base, this means the machine could be sitting on two feet and not twist the base, so leveling for tram isn't as critical. Now the things you'll probably need to mess with. Go ahead and keep a set of 7204 angular contact bearings on hand, ball screw thrust bearings. You will also need to know how to clean the tach feedback armature on your axis motors. It has to be done periodically and will make you think you have a bad thrust bearing. The number one machine I would pick would be a partner VM-17, but I'm unsure about running it on single phase with the AC drives.
