Centurion 6 Lathe Sample Program
Results 1 to 10 of 10
Thread: Centurion 6 Lathe Sample Program
    Jul 2013
    Default Centurion 6 Lathe Sample Program
    Hi all,
    I’m working on a post processor for a Milltronics lathe with Centurion 6.
    It would be very helpful if someone could post a sample g code program. The parts of the program I’m most interested in, are the beginning, the end, and the tool change sequence.
    Appreciate everyone’s help!
    Yogi
    Jul 2010
    Default Re: Centurion 6 Lathe Sample Program
    Hi Yogi, If all else fails try doing a conversational program, then go look at in text. Program, edit, text it will be the Oxxxx ( O1234) that you made.
    sportybob
    Jul 2013
    Thank you Bob! I’ll do that.
    I have a Fanuc post that looks to be very close, but needs some minor modification. Still, if someone has a short program to share, that would be very much appreciate.
    Yogi
    Jun 2010
    Take a look at this YouTube video
    "https://www.youtube.com/watch?v=wXLakFO42cA"
    May 2005
    duplicate
    May 2005
    yogi107,
    Did you ever get the start, tool change and end codes? The conversational output is not easy to follow as a lot of it is not commented - so a pain...
    thanks
    pt
  7. #7
    Jul 2013
    pt, yes, I put a post together that has been working satisfactory so far. The Centurion control accepts straight g-code, so I didn't have to mess with the conversational too much.
    Thanks,
    Yogi
    www.yogisworkshop.com
  8. #8
    May 2005
    Quote Originally Posted by yogi107 View Post
    Thanks,
    Yogi
    Yogi,
    I forgot to ask the obvious, what Cam system are you making the post for? I am looking for somebody with a Fusion 360 post for the Milltronics lathe. I can modify my own but I thought I ask as there are many hours of messing around if a noob like me is attempting this...
    Peter
  9. #9
    Jul 2013
    Peter,
    I’m using Gibbs, with Posthaste as post processor.
    Yogi
  10. #10
    Mar 2005
    Thanks,
    Yogi
    Hi Yogi, would it be possible for you to post a small program for me so I can see what it looks like. I just got a Milltronics ML-15 with the Centurion 6 controller and I'm trying to figure out how to write a g code program.
    Thanks Mike
