going by your first photo it looks like the motherboard has a Dallas real time clock module
which is a Dallas Real time clock IC and Lithium battery encapsulated in black epoxy resin
on some boards the RTC is plugged into a socket which makes it easy to change
other boards the RTC is soldered in and requires the correct tools and some practice de soldering IC's before you work on the mother board
john
