- Need access code for heidenhain tnc 415b to make backup files
Hi! Thank you in advance!
I have Mikron UME 600 and want to make backup files. For transfer data i use TNCREMO, and there are function backup files. I pres botton : scan system and machine files. Then there ask code number access plc.
I use all codes in heidenhain manual, but not one work:
123 MACHINE PARAMETER EDITING FOR END USERS (marked by *)
75368 OFFSET ADJUSTMENT
79513 DISPLAY OF VOLTAGE AND TEMPERATURE
86357 REMOVE EDIT/ERASE PROTECTION
95148 MP MODE
105296 COMPENSATION VALUE LIST
531210 RESETTING M 1000 TO M 2000 AND BYTES 0 - 127
620159 DOWNLOADING RUN-IN PROGRAM VIA INTERFACE
807667 PLC MODE
688379 INTERNAL OSCILLOSCOPE
Those codes work just tirect in tnc controller.
Any ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
