Mikron VCP600-HS
Results 1 to 2 of 2
Thread: Mikron VCP600-HS
    digicnc's Avatar
    Dec 2013
    Hanoi
    Default Mikron VCP600-HS
    Hello guys,
    I got a used milling Mikron VCP600-HS.
    It was out of order for some time now.
    My problems are: bad spindle bearings and i can not control-on the machine (it stays in emergency stop state and gives no other alarms).
    I checked the machine circuit and took the spindle out of the machine to see for details.
    But i got into another problem: i do not have any electrical diagram of the machine nor the spindle mechanical drawing. And from my opinion both are needed to fix the machine else i am stuck.
    So i would like to ask if any one here could share a copy of electrical diagram or spindle drawing?
    I would really appreciate your help.
    Below is my machine version:
    Machine: VCP 600-HS
    Control: TNC 430 Heidenhain
    6500kg
    3 Phase 400V 50Hz 40A 20kVa
    Control circuit voltage: 24V
    Schema No: 212.30.73.2x0
    Serial No.: 107.30.98.296
    Sound level: 75dB
    Model: 2001
    Validity: CN 30.0101.01
    digicnc's Avatar
    Dec 2013
    Hanoi
    bump. please check and help me.
Mikron VCP600-HS
Mikron VCP600-HS
