change Z position of the spindle in tool change
Results 1 to 4 of 4
Thread: change Z position of the spindle in tool change
    michael-p's Avatar
    Jan 2009
    Marsberg
    Quite a while ago, we got a second hand HAAS VF0. Before the delivery, the spindle got renewed. The spindle orientation was set but the Z position of the spindle when changing tools doesn’t fit to the changer. Thus causing a bang when changing tools.
    We have compared it to our other machine: on the changer the head needs to be around 1,5mm higher-. Unfortunately I can’t find the function that allows me to change the position. Which value in DEBUG need to be changed and how to I determine the right position?
    Would be very glad if anybody could help me solve that problem.
    Registered ogelle's Avatar
    Oct 2005
    Rutesheim
    Hello I will write you tomorrow evening. I noted down the answer to that problem at work.
    Regards Ogelle
    Oct 2005
    Rutesheim
    Hello
    Parameter blocker (7) off--- press Param/Diagn button--- Search parameter64 (64, then Cursor)---note value.
    Change value--- decrease value---- spindle stays up
    Increase value----spindle drive further up.
    Change number to 50000 gives you a traverse pat of 1mm---parameter blocker in
    Hope it helps you
    Regards Ogelle
    michael-p's Avatar
    Jan 2009
    Marsberg
    Thank you a lot!
