Alarm 144
Results 1 to 10 of 10
Thread: Alarm 144
    Registered dekasi's Avatar
    Aug 2007
    Halfing
    Hi guys,
    I have a Haas VF3 with Haas control system.
    Yesterday the following error description appeared.
    ALARM144
    Warning
    Machine will stop Functioning in 99,9 h
    Call Dealer for Unlock Code.
    I got a ‘billcode’ with my invoice.
    Where do I have to enter it?
    Aug 2007
    Halfing
    Hello guys
    I have a Haas VF3 with a Haas controller. Yesterday the following error message came up_
    ‘ALARM 144
    Call Dealer for Unlock Code’
    I got a ‘Bill Code’ with my bill.
    Registered ogelle's Avatar
    Oct 2005
    Rutesheim
    Hello
    I have done it in the past and I think I remember the following:
    Enter emergency shutdown- setting/graph button- onto serial number- enter Bill code- press ‘write’- done!!
    Regards Ogelle
    KAMIE's Avatar
    Jul 2004
    Saarbrücken
    Hello dekas,
    The Bill time Code is entered with the serial number. Usually there should be an instruction with the code that states where and how to enter it.
    Greetings Michael
    Gruß Michael<br><br><br><br>
    KAMIE's Avatar
    Jul 2004
    Saarbrücken
    Hello dekas
    The bill time code is entered with the serial number- usually you should have an instruction with it that tells you where and how to enter it.
    Regards Michael
    Aug 2007
    Halfing
    Hello,
    I can’t find the input field for the serial number anywhere. That’s my problem.
    I can change the name, IP address and other stuff but not the serial number??
  7. #7
    Aug 2007
    Halfing
    Hey
    I just can’t find the input box for the serial number- that’s my problem.
    I can change the name, the IP address and many others but no the serial number???
  8. #8
    KAMIE's Avatar
    Jul 2004
    Saarbrücken
    The serial number is positioned under setting number 26, key Setgraph -->general --> Nr.26
    Greetings michael
  9. #9
    KAMIE's Avatar
    Jul 2004
    Saarbrücken
    The serial number is under setting no. 26- button Setgraph – General- no. 26
    Regards
    Michael
  10. #10
    Oct 2005
    Rutesheim
    Hello
    I had a look at work today. Approach reference point- open writing security (setting7)
    Emergency shutdown- serial number (setting 26) – enter bill code- write enter
    Close writing security- finished.
    Regards Ogelle
Alarm 144
Alarm 144
