Hello guys
I have a Haas VF3 with a Haas controller. Yesterday the following error message came up_
‘ALARM 144
Machine will stop Functioning in 99,9 h
Call Dealer for Unlock Code’
I got a ‘Bill Code’ with my bill.
Where do I have to enter it?
Hi guys,
I have a Haas VF3 with Haas control system.
Yesterday the following error description appeared.
ALARM144
Warning
Call Dealer for Unlock Code.
I got a ‘billcode’ with my invoice.
Hello guys
‘ALARM 144
Hello
I have done it in the past and I think I remember the following:
Enter emergency shutdown- setting/graph button- onto serial number- enter Bill code- press ‘write’- done!!
Regards Ogelle
Hello dekas,
The Bill time Code is entered with the serial number. Usually there should be an instruction with the code that states where and how to enter it.
Greetings Michael
Gruß Michael<br><br><br><br>
Hello dekas
The bill time code is entered with the serial number- usually you should have an instruction with it that tells you where and how to enter it.
Regards Michael
Hello,
I can’t find the input field for the serial number anywhere. That’s my problem.
I can change the name, IP address and other stuff but not the serial number??
Hey
I just can’t find the input box for the serial number- that’s my problem.
I can change the name, the IP address and many others but no the serial number???
The serial number is positioned under setting number 26, key Setgraph -->general --> Nr.26
Greetings michael
The serial number is under setting no. 26- button Setgraph – General- no. 26
Regards
Michael
Hello
I had a look at work today. Approach reference point- open writing security (setting7)
Emergency shutdown- serial number (setting 26) – enter bill code- write enter
Close writing security- finished.
Regards Ogelle
