Need Help! Choosing appropriate driver for NEMA23 motor
Results 1 to 6 of 6
Thread: Choosing appropriate driver for NEMA23 motor
    Member Firecnc's Avatar
    Apr 2020
    Question Choosing appropriate driver for NEMA23 motor
    Hi Guys,
    advice is needed. I'm about to build a cnc for milling and drilling PCBs, wood, and occasionally aluminium.
    I choosed NEMA23 57HS76-2804A (1.9Nm, 2.8A, 57x57x76mm) motor, I think this will be strong enough. (what do you think?)
    Please help choosing the correct driver for it. Some youtube videos suggest TB6600, but I read some topics here and in other forums about that it often looses steps. Is that right?
    Could you please recommend me any other driver? I prefer cheap solutions shipped from China or Europe to avoid duty. I ordered other cnc parts from ebay, bangood, ali, etc.
    Thanks in advance,
    Steve
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Choosing appropriate driver for NEMA23 motor
    Hi Steve -Look at stepperonline Peter
    Nov 2013
    the stepper you have nominated has a moderately high inductance (3.6mH). Ideally with a 23 size (57mm) stepper
    you would select 1-2mh, 1 mH preferred and reject anything over 2mH.
    All steppers lose torque as speed increases, the lower the inductance the more torque will be retained at speed.
    In some respects low inductance is more important than holding torque. You'd think a 600oz.in stepper of say
    6mH would be better than a 400oz.in 1.5mH stepper. The 400oz.in stepper will probably
    have about 150oz.in at 1000 rpm whereas the 600oz.in will have 30oz.in if it ever makes 1000rpm, its more
    likely to stall long before it gets to 1000rpm.
    The 400oz.in unit is better overall....it will go 1000 rpm whereas the 'apparently more powerful' stepper will stall long
    before that.
    To counteract inductance use the highest voltage drivers and power supply you can find. Gecko drives
    are the gold standard for reliability but Leadshine AM822 are cheaper and still 80VDC capable.
    You want 80VDC drives and use an 80VDC supply, transformer/rectifier design preferred.
    No, its the stepper that loses steps but because the TB6600 has such a low voltage capacity it means that the stepper it drives IS more
    likely to miss steps and the faster it goes the worse it becomes. Aside from that the TB6600s tend to blow up fairly easily.
    Craig
    Member machinehop5's Avatar
    Aug 2009
    2 posts no flag...why?
    Apr 2020
    Thanks Craig.
    I haven't ordered the motors yet, so I can change them to an other if you suggest that.
    I saw Nema17 motors used for milling PCBs with 0.5Nm torque, and the other I mentioned has 1.9Nm, I tought it will be ok, but I accept your explanation of course. Every advice are welcome
    Speed is not the most important in this project, so I can keep the motors on low rpm for having the best performance.
    The drivers you mentioned are too expensive for this project
    Steve
    Nov 2013
    Heard that many times before.....and even more times I've heard 'I should have got...so and so motors' when the hapless buyer realises
    that speed was more important than he thought.
    Heard that before too....and yet the same buyer seems to scrounge up the money to buy the right ones....eventually.
    Craig.
