- need advice, first time using a compression bit
so i was finally able to convince my boss to buy a compression bit, its a whiteside solid carbide compression bit, 1/4 cut 1/4 shank, can compression bits be plunged into the cut like the other bits, i have seen other posts about ramping into the cut and im wondering if that is something i have to worry about with a compression bit, i would like to avoid any potential failures if possible as this is my first time using a compression bit
- You may not post replies
- You may not edit your posts
Forum Rules
