what causes this issue when cutting wood
Results 1 to 17 of 17
Thread: what causes this issue when cutting wood
    Feb 2018
    Default what causes this issue when cutting wood
    so im cutting 6mm plywood cirlcles(4x4") and im using the poor mans compression bit trick, im using a double fluted down cut bit to get through the top half and then a double fluted upcut to finish and im getting hairs in the middle of my cuts and dont know how to solve this problem
    Attached Thumbnails Attached Thumbnails what causes this issue when cutting wood-wood-jpg   what causes this issue when cutting wood-wood2-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: what causes this issue when cutting wood
    Why are you switching bits mid-cut? Most people use the same one for the whole thing; have you tried that? It seems that the cut quality might have something to do with the change-over.
    Feb 2018
    i switch between a downcut and upcut bit to imitate a compression bit, im trying to cut coasters that are printed on and need very little chipping on the top and bottom, which is working pretty well, but now for some reason hairs stay in the middle
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Maybe the upcut is slightly smaller?
    UCCNC 2017 Screenset
    Feb 2018
    the bits are identical, except for the cut direction, W2-418 D/U from cut guru
    Aug 2009
    Quote Originally Posted by bzen View Post
    There could be a slight difference from the factory. Tolerances do shift in the manufacturing process, and since they are "up" and "down" cut bits, they were more than likely made on different machines or at least different times.
    Juan
  7. #7
    Feb 2018
    i didnt think about it like that, is there something i can do to check for it being different sizes? besides the possible difference in sizes are there any other things that could be causing it?
  8. #8
    Mar 2003
    Shelby Township
    What if you cut a little deeper or shallower with the downcut?
  9. #9
    Feb 2018
    i tried changing the depths on the initial cut and that didnt fix it so im really at a loss right now
  10. #10
    Mar 2003
    Shelby Township
    It could just be the quality of the material you're using. It looks like the fuzz is at the joint between 2 layers? Could just be a poor glue joint? Or does it happen on multiple sheets?
    So, say you cut deeper than where the fuzz is with a downcut, then you should see the fuzz before you even run the upcut bit.
    If the fuzz is appearing only after running the upcut, than my guess is that the upcut is a smaller diameter.
  11. #11
    Feb 2018
    yea when i run multiple passes with just the downcut bit there is no fuzz, so im the thinking the smaller diameter is it, any tips for how to cut these coasters with as little chipping as possible with out using a compression bit
  12. #12
    Aug 2009
    I would duplicate your setup with the same bits on scrap material. Try using different cutter comp on one of the bits until you either eliminate the problem, or make it worse. If the problem is like ger21 says, (which does sound logical) then adjusting the cutter comp on one of them should help isolate the issue to one of the bits.
    Juan
  13. #13
    Feb 2018
    so i was finally able to convince my boss to buy a compression bit, its a whiteside solid carbide compression bit, 1/4 cut 1/4 shank, can compression bits be plunged into the cut like the other bits, i have seen other posts about ramping into the cut and im wondering if that is something i have to worry about with a compression bit, i would like to avoid any potential failures if possible as this is my first time using a compression bit
  14. #14
    Mar 2003
    Shelby Township
    You shouldn't plunge with any bits, and I wouldn't recommend it, but yes, you can if you want to.
  15. #15
    Feb 2018
    whats the best way to start?
  16. #16
    Mar 2003
    Shelby Township
    I always ramp in along a lead in move.
  17. #17
    Feb 2018
    ok ill have to practice ramping in (if you have any tips for ramping i think you can tell im pretty new to these machines), everything i cut is either prepared for me in our digital department or i create a file in coreldraw x7, but i was under the impression that plunging into a cut wasnt bad for the bit as long as the material doesnt exceed the max material thickness of the bit
