Z AXIS MOVES RANDOMLY
Results 1 to 6 of 6
Thread: Z AXIS MOVES RANDOMLY
    Feb 2017
    Mexico
    Default Z AXIS MOVES RANDOMLY
    Hi guys, hope you can help me, i got a cnc router form china, is the common heavy duty 1325, the machine was working fine in the past, is a machine the only use sometime and his main funtion is to surface cleaning wood slabs for dinning tables and coffe tables, but in this week is making an issue, it randomly plunge the z axis down, it star moving the z axis down little by little, ruining jobs and the slabs, the issue also happen when the job is finish and the machine goes to zero and the spindle stop, when the spindle is stopping th z axis moves, ill atthaced the link of the video of the issue and the photo of the machine.
    Also ill atthached the g code of the surface clenaing job.
    I change the pc hopping that resolve the problem but it doesnt, the issue is still there, im not expert and i cant see if the problkem is mechanical, config or something elsehope somebody help me with this issue and thanks for your time guys.
    link video:
    https://youtube.com/shorts/KL-B00Bh3lI?feature=share
    Attached Thumbnails Attached Thumbnails Z AXIS MOVES RANDOMLY-1325-jpeg
    Attached Files Attached Files
    Jun 2005
    Default Re: Z AXIS MOVES RANDOMLY
    Looks like the Z axis motor has losttetorque to hold motor weight. Add a nitrogen shock like on a car hood has a counter balance. The Z axis should stop dropping
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by gporthos View Post
    link video:
    You should be programing in Absolute G90 not G91 incremental
    There should not be a G71 or a G94 in your program a G71 is for lathe use
    What software are you using??
    Check the Grounding of the machine as you may have a problem with EMI noise when the spindle moves by itself like that
    Mactec54
    Feb 2017
    Mexico
    i use vcarve for generate g code and mach3 for controlling the cnc, im no exoert but how do i change the g code from 91 to g90?
    Jan 2005
    You need to select a different Post Processor
    I think your problem is more electrical than the program.
    Mactec54
    Feb 2017
    Mexico
    thanks for your fast repply, please check this new post winth an update because i cant modify this one, thanks a lot
    https://www.cnczone.com/forums/mexic...ml#post2507676
