Sanding Aluminum - with the grain?
Results 1 to 11 of 11
Thread: Sanding Aluminum - with the grain?
    Jan 2007
    Default Sanding Aluminum - with the grain?
    I've got some 220, 400 and 600 grit sandpaper that I'm using to finish aluminum.
    I've started experimenting and noticed quite a bit of different when I sand with versus against the grain. Is there a "best practice" for this?
    Also, I've never used "wet" sandpaper before. Is that a must-have for this process? I'm not looking for a mirror-finish; simply trying to get rid of endmill tool path marks.
    Thanks!
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Registered R&B Cutter Grin's Avatar
    May 2008
    I'd only bother with the 200 grit if your makes are really deep. 400 should be good, finishing with the 600. This depends on the rest of the finish though, and you may find that going 600 might make the area you're working on too polished compared to the rest of the piece. Wet sanding works really well in that it provides some lubrication to make moving the piece around easier. Quite often, using dry sand paper will cause you it to catch. When this happens, it causes more damage and ruins the paper- meaning you no longer have a nice even surface to sand with. Creases in sand paper are bad.
    R&B Cutter Grinding @ www.endmill-sharpening.com!
    Jan 2007
    R&B - thanks for the info!
    Registered HuFlungDung's Avatar
    Mar 2003
    If the nature of the toolmarks is mostly appearance and not actual fingernail-snagging roughness, Scotchbrite works fairly well. It is available in different coarsenesses, too. It doesn't load up like sandpaper.
    If one must sand to remove actual toolmark gouges, then you've probably got a thousandth or two to remove and will have to use sandpaper. If you have small fillets and corners to get into, a selection of sizes of vinyl tubing comes in handy as a backing. You can wrap the paper around the tubing to approximate your fillet radius, yet the tubing is flexible enough to give and follow the contours better than fingertip or a rigid backing.
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    Quote Originally Posted by tikka308 View Post
    Thanks!
    if you going against the grain on raw stock then you may find a difference ,you shouldn t see a difference on a machined part
    sometimes aerospace parts need to have the grain running a certain way on the part for documentation sakes
    varsol works well for wet sanding , wet sanding keeps paper unclogged
    what paper are you using in your polishing tutorial video when your sanding in the bathtub ? http://www.cnczone.com/forums/showthread.php?t=53095
    i really don t agree with the sanding block you use in the video , you should be using a smooth flat surface , uing a pad with soft foam will round the corners and you will not get an even smooth finish
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jan 2007
    dertsap - you're right, the foam was a poor choice because it did subject the corners to being rounded. The sandpaper is 3M Imperial - http://solutions.3m.com/wps/portal/3...glWK3JKNBXNXbl
  7. #7
    Oct 2005
    canada
    i had an aluminum disc that mounted in the drill press chuck , on it i used the round sticky one side sanding pads for orbital sanders , a 600 grit pad worked incredably well ,the finish was in comparison to a ground finish , except the grind marks didn t run straight if you know what i mean , it was easy to polish from that point
    it's a simple thing to make and saves a ton of hand work , it's something i've completely forgotten about until now , i think i'll have to do some digging and see if i still have it ,
  8. #8
    Aug 2015
    Default Re: Sanding Aluminum - with the grain?
    Hello, if you need help. I am a professional Aluminum Sander and Polisher. I like to use a 400, 800, and 1500 for the best results. Watch this video for an instruction if needed.
  9. #9
    Aug 2015
    Here is a slightly better version of the video for all so see.
  10. #10
    Aug 2015
    I am a professional, and I sanded from a 220 grit sandpaper all the way up to a 5000 grit, Hope this video helps you. Good luck
  11. #11
    May 2006
    Skills trade.....You are the professional polishing man...
    My work is amateur, with no wheels, block and soft block only to 3000.
    Attached Thumbnails Attached Thumbnails Sanding Aluminum - with the grain?-lp-reflection-outside-jpg   Sanding Aluminum - with the grain?-imag0322-2-jpg   Sanding Aluminum - with the grain?-imag0331-jpg
    Been doing this too long
