- Calling all CNC machine builders, mechatronics, Automation folks.
Hello,
Like most of you I caught the DIY CNC bug and can't shake it. Covid 2020 provided some extra bandwidth to re kindle a DIY machine build. One main difference is that I wanted to set out with a goal of being able to make a compact machine the size of washing machine with a work envelope of a shoebox....that had the rigidity and accuracy to machine any type of material. After a year of banging our heads against the wall.....(hats off to all the DIY guys, You Tubers and those that have braved this challenge) we are very close to having a MVP (Minimum Viable Product). We are looking for professionals and expert enthusiasts that can help consult with the final integration of Tool changer systems, Electronic packaging, sheet metal enclosure work, Production level castings.
If this is something that is up your alley I would love to hear from you.
Arin Chang
M 650-302-8255
- You may not post replies
- You may not edit your posts
Forum Rules
