Hi Pippin - Cleaning steel is easy if you use vinegar. It will remove mill scale laser scale etc. Just need a bath big enough. About 6 hr soak will do it.... Then there is cast concrete or engineering grout. That would be my go to at present. To produce 90deg joints a flat can be bent into the back plate so the connection is square... Peter
