Need help with calculating tool nose compensation
Results 1 to 3 of 3
Thread: Need help with calculating tool nose compensation
    Member OmriOhayon's Avatar
    Oct 2021
    Default Need help with calculating tool nose compensation
    Hey guys, Im writing a CNC program (not a g-code) for a lathe machine and im having some trouble with calculating the tool radius compensation needed for arc cutting.
    When the arc angle is 90 degrees there's no problem, the problem is when i want to cut an arc that is less than that.
    Are there any formulas for calculating the compensation needed with dependece on the tool radius and the arc radius?
    Thanks!
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Need help with calculating tool nose compensation
    hy can you join several 90 degress arches, that have different radius, and different centers, and are not tangent ?
    handling rad comp requires offseting and sometimes auxiliar geometry in between not tangent entities
    please share a bit more details, maybe an example, so to see exactly where you get stuck, and i will help you / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    "calculated" tool path for 90°, covers the path for less, right? Just find the point of transition to the next shape element.
