My understanding is dual screws are used on a moving gantry to reduce the possiblity of racking.
With the rails you're using and a central screw --racking of the moving table doesn't look likely so no need for dual screws in my opinion.
Is that now enough power for that axis ? Others would calculate that better than I can. The problem with changing a design midway, we've all done it.
