I have always used the J series Poly-V-Belts 8 to 10 Rib 12 Rib is standard, 10 Rib which have been very successful with 5Hp with a minimum of 4" pulley Dia, some Belt suppliers will slit the Belts to how many ribs you want here is some information
A Boss 5 Mill with the standard 3Hp motor
