Web browser image searches for "industrial control cabinet" or "Control Panel" have yielded some very good examples of what to do (and not to do). I wish there was a beginner's guide to industrial control panels, but I haven't found one yet.
I don't do this for a living but I've built a few panels over the past couple of years. Here's what I've learned from some trial and errors; please take it with a grain of salt.
1. It helps to draw everything out first before you get an enclosure.
2. It really helps to lay it out in 3D CAD - most vendors have 3D models available for download and you can 'sandbox' the enclosure and components.
3. If you can, put heat-generating components towards the top. Drives, VFD's, power supplies. Pay attention to the spacing for drives and other heat-generating components published by the manufacturer.
4. Think about internal airflow and how to exhaust the heat everything will generate.
5. Make a list of components and organize them by type and voltage.
6. Try to minimize the different number of voltages. By this I mean try to use drives that are all 240, or all 120, or all DC. Same thing for relays, contactors, sensors - it's a pain if everything is different and you need 5, 12, and 24Vdc in the same cabinet.
7. Drawing a wiring diagram or schematic first really helps before you start buying things. But don't agonize if you wind up needing another relay or whatever.
8. DIN rail terminal blocks are your friend. Just make sure to get more than you need, and that the types, amperage rating, and accessories are all the same. Each block manufacturer has their own proprietary jumpers, end plates, fuse holders, etc. Good deals can be found on Ebay, although you might need to buy from multiple sellers to get enough of the same brand/series.
9. You can never have enough room in the enclosure. If everything fits on paper, go one size bigger (at least)
10. Make sure you have room for the wireways and enough room between components so you don't need tweezers to make connections. And make sure you have room, terminal blocks, and power for future expansion or re-wiring.
11. Try to separate power components from signal components. Shoot for an AC side and a DC side. Or put the sensitive (to noise) components in a separate enclosure.
12. Think about the power flow when you lay things out. Power comes in and goes to a disconnect or fused disconnect. Then to a distribution block. Then to individual circuit protection. Then to contactors (for drives) or directly to a DC power supply. AC from contactors goes to the drives or to line reactors and then to the drives. DC goes to a distribution block and then to DC fuses (or breakers). And then on to components, relays, etc. This is all the 'power' side of things. The 'signal' side of things is what triggers the contactors, relays, motion controller, etc. Usually all DC, and relatively low amperage.
13. I prefer that all buttons, displays, lights, etc. that the user interfaces with be 24Vdc. 120VAC is permitted by some codes, but I am not comfortable with that on a flood-coolant machine. This adds some complexity by needing a larger DC power supply and extra wiring, but I think it's safer.
14. Having a dedicated electrical CAD program can make things so much nicer. TinyCAD is free and I use it for everything. Steep learning curve but it rocks compared to paying for something.
15. Keep analog signals (FRO/SRO), encoder cables, and step/direction cables shielded and well away from 'noisy' stuff, like drives, VFD's, relays.
16. Star ground - learn it, love it.
17. Labeling - I started off using a label maker; that was terrible. Then I used a labelmaker and clear shrink tubing for the wires - better, but still fussy and time-consuming. Last job I did I treated myself to a Bluetooth labelmaker that prints directly on shrink tube - OMG. Magic. Same labeler can use regular tape for labeling terminal blocks, components, etc.
18. Speaking of tools - buy or borrow decent crimpers, strippers, and so forth. You dont' need super-expensive stuff, but having the right tools makes it so much less painful. I like my iWiss stuff so far. Not perfect, but cheap and light-years ahead of the really cheap Harbor Fright grade things.
19. Get a wire ferrule crimper and a pack of ferrules. So much tidier and you are less likely to have a stray strand touch something it shouldn't.
20. Think about maintenance and troubleshooting - will what you are about to do be easy to figure out? Does the basic layout make sense? The next guy in the panel will probably be you, and you won't remember everything in a month or year. If you have to change somethign from the diagram - UPDATE THE DIAGRAM.
21. Wires shouldnt cross over components inside the enclosure. Make each connection long enough to gracefully lay in the wireways.
22. Spend a little more money on components and buy from places like Automation Direct instead of trying to save a few bucks by sourcing the absolute cheapest things. Having all the relays (or whatever) be from the same vendor/manufacturer makes planning, wiring, and installation easier.
23. Buttons, knobs, lights, switches. Use the 'industrial' modular stuff that have separate contacts and actuators instead of el-cheapo items like you see at the auto parts store. The modular switches take up more room, but they are easier to wire and generally feel/look nicer to use. You can also stack contacts to have a multi-function switch if you need it. Don't forget that like terminal blocks, modular switch contacts are not usually interchangable between brands.
24. Before you buy anything, take your list and start making "power budgets." By this I mean:
- how many amps do you have total
- how many amps does each thing draw - including inrush current
- do you have enough 'overhead' on both the AC and DC sides? Or do you need a bigger control/DC power supply or a bigger breaker in your house/shop panel?
- Can the relays or whatever handle the amps you're sending through them? Remember that power switching devices (buttons, switches, relays, contactors, etc.) may not have the same rating for AC and DC power. A "10A" relay might only be able to handle 5A or 2A when switching DC.
25. Buy good quality wire. It actually makes a difference, and if you buy way more than you need you'll be less likely to fudge a connection from one thing to another to try and save that piece that just isn't quite long enough.
This is getting long, sorry. And I don't have 50 years of experience. Photos below of what what I thought was OK, as well as some examples of how not to do it (sometimes in the same photos).
-Ralph
First real attempt at CNC wiring. My mill - pretty bad, but at least it works reliably and I kept the high-power stuff in a separate enclosure from the signal components.
Getting better on #2 (pic rotated). DIY plasma for friend. Zero noise-related issues after a year of almost daily cutting.
Think I'm getting the hang of this, but still not a pro. (#3) Industrial automation machine w/Clearpath servos. Note how I separated the AC and DC top and bottom, plus extra terminal blocks & PLC I/O for future expansion. This was an actual paying job.
Operator station for the same machine. Field wiring not fully tidied up in this photo.
