I'm building a desktop injection molding machine like in this image but i'm confused about the lever design is it second or third class?
I know that the force is 12000 PSI , How can i calculate the arm length? 2505785bc44b79cfea144ec1c788e973 — imgbb.com
Re: Desktop injection molding machine lever design
12000 PSI is the pressure in pounds per square inch. Multiply it by the area on which that pressure is acting (ie the piston face) gives you force in pounds. That force divided by the force you want swinging on the handle (what, 60lb max?) is the gain the lever needs. Which in turn gives you the length of the handle.
