Gypsum Briquetting Machine of Fote Heavy Machinery
Most people think that it is easy to make the desulfurization gypsum. Actually, it is not as simple as you image. It is technical to produce the desulfurization gypsum. While, nowadays, there are a lot of difficult problems that urgently needed to be addressed. Most of them are related with the researches on the basic technological theories of desulfurization gypsum. At present, the working capacity of desulfurization gypsum briquette machine is only about 5,0000 tons to the largest.
Based on the poor working capacity, it is quite hard to develop the production scale. To change this condition, the only way is the joint production. Without the help of adhesives, desulfurization gypsum briquette machines of Fote briquetting machine manufacturer can suppress the watered material of desulfurization gypsum into briquettes or balls for one time. The finished briquettes, without the need to be dried, can be directly used for other purposes.
Featured in the great strength and high density, the finished briquettes are convenient for transportation and packaging. Featured in the impact structure, easy maintenance, simple operation, short technological process, low energy conservation and low failure rate, the desulfurization gypsum briquette machine can be a good helper for you. By virtue of the systemic after-sales service, Fote has established favorable long-term relationships with many mining enterprises at home and abroad.
As a professional supplier of desulfurization gypsum briquette machines, Fote has made the production for more than 30 years and is known as the NO.1 brand of China mining machinery. Surprises for you on our official website!
