Well the saga continues...
I took the time last night to measure the voltages from the power supply. That was fun getting to the pins with my meter! Everything measured fine, according to the specs the voltage can vary 15% and nothing measured out of that range.
All the Led's that are supposed to be on are and the ones that are supposed to be off are off.
I also looked to see what happened differently than the identical machine I have next to this one. All the same Led's light up with the same commands.
I did find no reference 10v from the cnc when a spindle speed was commanded,But If I use the manual start button there is a voltage signal.
Regards,
Cutmore
