Need Help! Lathe turret fault
Results 1 to 2 of 2
Thread: Lathe turret fault
    Member Rukam22's Avatar
    Sep 2019
    DARFIELD
    Default Lathe turret fault
    I have a lathe with MITSUBISHI M70 and I have problem with my turret. After 20-30 minutes I have alarm "turret fault". My servo driver for turret is MR-J3-100A-RJ and when the alarm appears, on the screen of the servo driver I have only AL--..If someone can advise me because I think I need to change with new servo driver.
    Nov 2012
    Default Re: Lathe turret fault
    Sorry... you have a new fangled control and I don't know much about these. However, I can say that I think Mitsubishi really has kept the same code across their generation of controls... As such, I'd be very surprised if you can't press some buttons on the control to gain an ID for the alarm. Those seem to be consistent across the Meldas generations, so it shouldn't be too hard to find the meaning of the alarm. You also can probably cycle through some menus or something on the amp itself so you can see the alarm value. If not, then it could well be that the amplifier is bad.
    If the amp is bad, you probably can simply set the ID to match the original one and replace the amp. Mitsubishi support should be able to help you with all of this though. The M70 is a new enough control that they'll probably talk with you. Honestly, they are a great company and give you a lot more support than I would have expected... Give 'em an email or call...
Lathe turret fault
Lathe turret fault
